sean116688 Posted September 4, 2017 Share Posted September 4, 2017 I have a 1994 Lexus LS400, approximately 210,000 miles on original engine and transmission. Recently, it has developed a very noticeable exhaust smell when running. When the engine is shut off in the garage, the smell is particular objectionable and stays in the garage for quite a long time. I wouldn't characterize it as a rotten egg smell, but it is quite objectionable. It is not noticeable in the cabin at all. I checked underneath the car when it was running, and it didn't seem to have any leak in the exhaust system. I don't have any code showing on the dash. Any help is much appreciated. Quote Link to comment Share on other sites More sharing options...
Alexander the o.k is back Posted September 6, 2017 Share Posted September 6, 2017 Xiang, Sounds like incomplete combustion byproducts. Check all ignition related components such as: wires plugs distributors and most probably a failing coil. Search the forum your answer is already here. Other things to look for: oil / PS fluid dripping onto heat shield or cat. If you or a friend has an obd2 scanner, hook it up and post what you get. I think obd1 was thru 1993. Quote Link to comment Share on other sites More sharing options...
