My 92 SC400 needs Nakamichi amp. I pulled it out, but, the only label I see is B3240 02209. Other white label is washed out from water damage. I see ebay sellers offering amps with different numbers: what I should be looking for?
And the car needs all 4 shocks replaced. Amazon is selling shocks for about $70 each. Are these correct part numbers for a 92 SC400? Appreciate your help.
KYB GR-2 Gas 341161 & 341162
Also, Amazon has following strut mounts: are these correct part numbers? If anyone used these, appreciate confirmation
KYB SM5564
KYB SM5186
  • 3 weeks later...
I'll be pulling my Nakamichi system and it'll be up for sale
Hi Returd... did you post the amp sale?  is it in classifieds?
I haven't pulled it yet.  I'm tearing into my parts car first to see what i can salvage from it.  I'll get into my nak equipped driver some time next week.  When i do I'll pull numbers from it.  From what I recall it's mounted under a clear plexi cover up on the side of the driver side rear quarter.  There's also the factory disk changer
  • 3 weeks later...
pulled my amp and 12 cd changer today
amp 86280-24120
B324UL0A
serial 01562
Trunk was dry as a bone and everything worked prior to pulling
