mercedes84black Posted January 7, 2017 Share Posted January 7, 2017 Lately while working on my 91 ls400 I started driving it without the cooling fan shroud and it's running hot. Will that cause this problem. When I'm moving the temp begins to go down but stop and go driving it seems to get hot faster Quote Link to comment Share on other sites More sharing options...
TrevC Posted January 9, 2017 Share Posted January 9, 2017 Yes, that would definitely make a difference as the air is no longer being directed through the radiator. See if refitting improves the situation Quote Link to comment Share on other sites More sharing options...
Exhaustgases Posted January 10, 2017 Share Posted January 10, 2017 Then you have to ask yourself, why did the Lexus engineers decide to use them? Running hot? Not a problem until things start to melt. So do you think the Lexus engineers got it all figured out? Quote Link to comment Share on other sites More sharing options...
Flight_Engineer503 Posted February 13, 2017 Share Posted February 13, 2017 when you say "running hot" what do you mean..is it going 3/4 of the way up to high limit? Or just bumping up slightly over 1/2? Ive been running without a shroud in texas heat for over 2 years and its just fine. Are you still getting heat from the heater? Whats the mileage on your thermostat? Water pump leaking? did you recently open up the cooling system for maintenance? Quote Link to comment Share on other sites More sharing options...
