Has anyone had experience with OBD II code P0773 - shift Solenoid. My 96 Lexus starts giving me this code. Do you know where the solenoid is?
1 hour ago, Exhaustgases said:
You drain and remove the transmission pan, and its found on the valve body.
Thanks Exhaustgases for your reply. The ECU was bad. I swapped it with a spare that I bought a few years back.The code went away.
