I purchced a new 2016 Rx350, Sweet car every opt. available (even things I didn't know exsisted)
Well I put on a trailer hitch as I do with every RX I've owned since 2003, and this is the first one that the Lighting plug under the read of the car was dead.
No power was coming out. The Fix is a Hitch wire converter box that is added at the dealer when you buy a hitch from them at $1000,00 or so.
If you don't want to hack into your wireing harness with some aftermarket converter then this is what you need.
2016 -  ****  = P/N  PT725-48160
2010 - 2015 = P/N PT219-48101
First off I was told both boxes I listed are the same and are interchangable, but I opted for the correct P/N
This is a box that plugs into your existing wirering harness in the passenger rear truck panel and allong with
a 30 amp fuse into your fuse box will make your OEM Hitch wireing plug work like it was suppost to.
I attached the install PDF, also.
Good Luck .
MY16 RX 350-450h Tow Harness Converter Kit IssC.pdf
  • Like 2
