How to remove the trunk release handle inside the trunk
I am going to install a backup camera on my 2005 ES330. I need to be able to remove the trunk lid liner to install the camera. I will have to remove the release handle in order to drop the liner. I have looked at the handle but haven't figured out how to get it off?
Any ideas would be appreciated.
spraychaser,
Its been a few years since we had our last ES330, but if its anything like our present ES350, don't worry about it. It'll be like removing an inner door panel.
Once you pull all of the fasteners and the screws at the pull down handle recess, the panel will fall away far enough for you to reach in behind the panel and undo the cable or rod to the trunk lock mechanism. The emergency handle will stay with the inner finishing panel for the trunk. I can't say for sure .... but with all of the cars I've had apart and repaired over the years ... I'd bet money on it. Good Luck!
