Brake Warning Light
This morning my Brake warning light came on.  I did not have my parking brake on when I parked for the night and I don't think I have used the parking brake in the last month.  It is very flat around here.  I set the parking brake and released it with no affect on the warning light.  My brake fluid is right where it should be, mid-way between full and low.  Is there anything else I should check?
harv5-42,
In the past I've had this same issue on a 2004 Subaru. At first I thought there was a brake issue, but a simple topping up of brake fluid to the MAX line, cured the dash brake line issue.
I'd sure try that before anything else. Let us know how it works out.  Good Luck!
