lexi79 Posted November 6, 2015 Share Posted November 6, 2015 HI Guys, I just purchased the H11 HID kit(DDM Tuning) for the GX470 low beams, Im a bit confused on whether this is a simple plug and play or I have to do some kinda of mod to get the HID wire harness wire to connect up with the Stock wire that connects to the bulb. Please if anyone has used DDM Tuning HID kit or other if you can explain "how to connect the HID wire to the stock bulb wire"? Do I need to remove the casing cover off the stock bulb wire to line up the two pins male to female(stock wire)?? Thats the main issue I"m having. Thanks for all those who chip in. Quote Link to comment Share on other sites More sharing options...
