I have 2001 Rx300 with 205K on it. What should the engine compression be on each cylinder when I do a compression test?
Well. Try to find the service manual (as distinct from the owner's manual) for your car, it should have such data
  • 6 months later...
ideally compression is like blood pressure. Must be uniform across all cylinders. Dry compression around 150 psi all across is fine when the engine is cold.
