99 Rx Randomly Sputters And Then Brakes Go Out.battery Problem?
dkr919
Car will run fine then out of the blue it starts running rough and not coincidentally the brakes go almost completely out at the same time. Would low power from the battery cause these problems?
I've been reading posts on similar problems as mine and have recently pulled codes p1348 and p1354 which seems to point to the oil control valves. From what I've read it seems a straight forward fix,(new valves and clean filters).
Can the valves also be cleaned or new ones required?
Also are both valves the same part and interchangeable on either bank?
