Leaky Valve Cover Gaskets
Hope this will help someone......v-6 has shouldered bolts on v/covers, it will not allow the cover to be tighten down enough .........and old trick we used for oil leaks......loosen bolt and wrap a cotton string around the bolt and tighten.....its works and saves hundreds of dollars.....
Hi Jack and welcome.
That's what I call the "Shade Tree Mechanics" book of dealer Vaccine's. You can save money while avoiding some of the "infections" you get from the dealer.
Thanks for the idea.
Paul
  • 1 month later...
Yea I think the valve cover bolts have crush washers.
If you try and do a valve cover leak job without putting some spacers between it, the bolts will never torque to spec.
When I did mine I just used 2 5/16 washers for each bolt. Gave enough space for the bolt to make the valve cover tighten to spec.
