BLAISERSC430 Posted April 1, 2015 Share Posted April 1, 2015 Just had my 02 SC430 in for service with check engine light. Pulled an Error Code of P-0430. Bank 2 (Passenger Side Catalytic Converter 02 Sensor). Had the local shop check it out and said the Catalytic Converter was bad along with the "Y-Pipe had a crack in it. So I decided to replace both front Catalytic Converters and Y-Pipe with new. Order the parts, parts came in and took the car to the local shop. Shop owner says he can bolt it up in about a 1-2 hours. Then got a call from shop owner and said the Console of my car has to be removed because that is where the 02 Sensor Plug Connectors plug in from the Pipe. Anyone ever come across this? Seems odd that the plug connectors are not right there by the Y-Pipe? Quote Link to comment Share on other sites More sharing options...
TeeBear Posted June 25, 2015 Share Posted June 25, 2015 I have a 03 SC430 and the end of that sensor is under the passage seat. Had my replaced at a shop not long ago. The 02 and 03 should be the same. Hope this helps Quote Link to comment Share on other sites More sharing options...
