youngdoog Posted April 15, 2004 Share Posted April 15, 2004 I went to change out the PCV valve, and after lubing, grunting, and everything else to avoid !Removed! up the grommet-I destroyed the grommet. I did retrieve the broken grommet. So my question is-Can I get a new grommet only? PCV valve grommet = 90480-18001 If so, do I have to remove-and how- the valve cover? I knew I'd screw this one up-It was in there too secure. Thanks Quote Link to comment Share on other sites More sharing options...
99lsguy Posted April 15, 2004 Share Posted April 15, 2004 Oh yeah, no problem on the grommet - it is separate part the PCV valve @ KC lexus runs around $5.50, so the grommet is probably about the same..... My guess is the grommett should just pop in place from the top of the valve cover, no need to remove anything...it was obviously brittle and time to go!! 99 insp.pdf Quote Link to comment Share on other sites More sharing options...
