Torque Specs 2000 Ls400 Transmission Pan
cmshoot
If you haven't removed the pan yet, you might not need to know. There is a drain plug for the transmission fluid. Drain, fill, drive, drain, fill, drive a few times. Otherwise, you need not only the torque specifications but the pattern as well. Very, very important not to over tighten and distort the fit. No filter, just a screen to see anyway.
Hate leaks. Probably means that someone has had it off before and did the over torque thing. I've seen some that are bent iin at every bolt point. Well good luck. Follow the pattern and step torque.
