topgun129 Posted October 30, 2014 Share Posted October 30, 2014 Hi, I have a 99 ES300 with 130K and I was getting p0171 error code and had my upstream oxygen sensor replaced with a high quality Bosch part. Now its coming again after drive for only a few miles. Its coming up twice. Any ideas what might the culprit be and any solutions? Thanks! P.S. I'm not noticing any changes in the performance in the car. Quote Link to comment Share on other sites More sharing options...
gbhrps Posted October 30, 2014 Share Posted October 30, 2014 topgun129, The following list applies to the trouble code you have. When more than one cause is listed you are ill advised to just jump to the conclusion that swapping out a single part can cure the issue. You may well have changed out a part you didn't need to. Obviously one of the other causes listed is the one that needs to be addressed. If you're not capable of tracking down and correcting any that are listed, you need to save money by taking the car to a qualified mechanic who can. Good Luck! Possible causes for a Lexus P0171 code: - Intake air leaks - Faulty front heated oxygen sensor- Ignition misfiring- Faulty fuel injectors- Exhaust gas leaks- Incorrect fuel pressure- Lack of fuel- Faulty Mass Air Flow (MAF) sensor- Incorrect Positive Crankcase Ventilation (PCV) hose connection Read more: http://engine-codes.com/p0171_lexus.html#ixzz3Hf4CoOEX Quote Link to comment Share on other sites More sharing options...
shopper Posted July 19, 2016 Share Posted July 19, 2016 I spent hundreds, maybe thousands of dollars over the life of my 2000 RX300 trying to resolve the P0171 error. I've had O2 and Mass Air Flow Sensors replaced numerous times to no avail. The car always ran fine except for straining, pinging and loss of power when climbing. I had been using regular gas for 16 years and decided to try a higher octane - 91. Voila! No more trouble climbing, no pinging, and best of all the error code is gone! Quote Link to comment Share on other sites More sharing options...
