Snoopygal Posted June 16, 2014 Posted June 16, 2014 I have had a couple of instances where the AC drain was stopped up and flooded the foot wells of the car. However, after unclogging the drain hose and it draining well outside the car, I am still getting water inside. Is there another place the AC could be leaking? Thanks for any help.
Rogerm Posted December 7, 2014 Posted December 7, 2014 Your sunroof drain tubes need to be cleaned... I did mine... I don't know where I found out where they were and how to do it. used a coated flexible steel cable. lots of water Did it from the top all four corners. and from under the car up. Used small wire as well.... just keep going deeper each time and adding water. mine had algea build up I think. Fixed the problem...
