ocmikeb Posted May 1, 2014 Posted May 1, 2014 1993 LEXUS LS 400. No AM reception and FM is week. Antenna seems to be working. Disconnected mast and signal got worse.
landar Posted May 2, 2014 Posted May 2, 2014 Welcome, Mike. What I would do is get another AM/FM antenna(does not need to be toyota), even a piece of wire, and temporary substitute that for your existing antenna. That will give you an idea of whether the factory antenna is on the fritz.
vissine Posted June 4, 2014 Posted June 4, 2014 1993 LEXUS LS 400. No AM reception and FM is week. Antenna seems to be working. Disconnected mast and signal got worse. Does the antenna extend when the radio AM/FM switched on? I notice the antenna is longer for AM.
ocmikeb Posted June 4, 2014 Author Posted June 4, 2014 1993 LEXUS LS 400. No AM reception and FM is week. Antenna seems to be working. Disconnected mast and signal got worse. Does the antenna extend when the radio AM/FM switched on? I notice the antenna is longer for AM. YES IT DOES. I NOTICED THERE IS AN ANTENNA CABLE UNHOOKED AND TAPED IN THE TRUNK NEAR THE MAST. I ASSUMED THAT WAS A SPARE BUT I'M NOT SURE NOW.
vissine Posted June 4, 2014 Posted June 4, 2014 YES IT DOES. I NOTICED THERE IS AN ANTENNA CABLE UNHOOKED AND TAPED IN THE TRUNK NEAR THE MAST. I ASSUMED THAT WAS A SPARE BUT I'M NOT SURE NOW. You may want to check the power amplifier. If the amplifier is good, then the receiver maybe faulty.
