theazz Posted April 7, 2014 Share Posted April 7, 2014 First this is my 2nd SC430 (bought it a week ago). Had to sell my first one to pay for a wedding. Anyway I have a static sound coming behind the dashboard. Turned everything off except the on position on the ignition. Static still there. So I started pulling fuses to see if I could isolate the problem. Yep I found the fuse on the block on the drivers side. It is ckt 6, 7.5amp. Book says its for Tilt and Telescopic steering, Power door lock system, SRS (something with airbags, there is another fuse that says SRS) and Power seat system. Any ideas on where to start before I pay Lexus to find it. Quote Link to comment Share on other sites More sharing options...
ShawnOklahoma Posted April 7, 2014 Share Posted April 7, 2014 Does the telescopic steering work properly? Might be a burned out motor or shredded gear teeth. Check the tilt and telescoping features and let us know. Quote Link to comment Share on other sites More sharing options...
theazz Posted April 7, 2014 Author Share Posted April 7, 2014 Telescopic and tilt work perfect no intermittent noise. Quote Link to comment Share on other sites More sharing options...
ShawnOklahoma Posted April 8, 2014 Share Posted April 8, 2014 Could it be the headlight leveling system? I've heard of other owners experiencing problems with them and it would result in a similar sound if they just continued to whir as they aren't leveling out. The blown fuse could just be a coincidence. Quote Link to comment Share on other sites More sharing options...
theazz Posted August 12, 2014 Author Share Posted August 12, 2014 Finally found the problem. Decided to dive into this and started to pull fuses to see if it stopped. Found the fuse and started to take things apart from the power source to the last thing in the circuit. Turns out it was a bad connector connection on the back of the AC control unit. Happy Days theazz Quote Link to comment Share on other sites More sharing options...
ShawnOklahoma Posted August 13, 2014 Share Posted August 13, 2014 Wow! Congrats on tracking down the problem! Way to just dive in and go for it! Hopefully it will be an easy and cheap fix. Quote Link to comment Share on other sites More sharing options...
theazz Posted August 13, 2014 Author Share Posted August 13, 2014 Luckily I was able to unplug and plug in again and the noise stopped. So I'm thinking just a bad connection at least for now. Quote Link to comment Share on other sites More sharing options...
theazz Posted September 16, 2014 Author Share Posted September 16, 2014 Static or gurgle sound is back. Apparently others have had this and it's faulty servo's. There are a total of 4 on the sc. Cleaned all 4 (trying this first) . Sure hope this does the trick. Theazz Quote Link to comment Share on other sites More sharing options...
theazz Posted March 29, 2015 Author Share Posted March 29, 2015 Forgot to get back to everyone after I cleaned my servos. Yes they were very dirty. Cleaned them and everything works great. No more noise in the dash. theazz Quote Link to comment Share on other sites More sharing options...
Cnnumber Posted November 4, 2015 Share Posted November 4, 2015 How do you get to the servos? Do these servo motors operate blending doors for mixing fresh air and air conditioned air. Thanks Quote Link to comment Share on other sites More sharing options...
theazz Posted November 10, 2015 Author Share Posted November 10, 2015 They do operate the mixing doors for the heat/ac. They are located under the dash and behind the dash. Not too difficult. Mine had some dirt and lint on them. Just clean and put back in. You can also buy new ones for about $120 each but mine just needed cleaning. I have 94k on the vehicle. theazz Quote Link to comment Share on other sites More sharing options...
