On a 2007 ES350, getting a Check Engine light with a code of P0351. What is this code? I thought it might be an O2 sensor.
P0351 is the code for "ignition coil A Primary/Secondary Circuit Malfunction". A little online searching shows you probably have a bad "coil on plug" on cylinder #1, which is the right rear (passenger side at the firewall) most cylinder.
You might try changing that coil pack for a known good one to verify, if you can locate one from a wrecker/friend/etc. Good Luck!
