2003 Es300 Rear Shelf Speaker
Hi Peter and hope your haveing a good day up in the north country.
I did a quick search of our data base and found this posting on removing the parcel shelf. In order to do that you must also remove the back seat back rest. It really isn't too hard, but it takes quite a bit of time and patience.
There are other postings in the data base on this subject and I would suggest you check them out. If I remember right there may be one or two with some photos attached. The search window is at the top of every page and to the right side.
If you are unfamiliar with speaker dynamics, impedance and wattage, I would suggest you try Crutchfield for help with a replacement speakers.
Paul
http://us.lexusownersclub.com/forums/topic/1351-95-speakers/
