Rx300 Grounding Points
ripready
I'm looking at doing a Big 3 cable replacement and need to know where the ground points are in a 1999 RX300.
I know there are two near the alternator housing attached to the shock tower and two opposite on the other shock tower.
There is one I can see under the air filter which I think is connected to the transmission. That might be the one coming from the negative of the battery terminal.
Anywhere else?
Thanks in advance.
