88anthonyd Posted December 26, 2013 Share Posted December 26, 2013 When changing thermostat are you suppose to fill coolant in water inlet housing or do you just put coolant in reservoir? Quote Link to comment Share on other sites More sharing options...
landar Posted December 26, 2013 Share Posted December 26, 2013 I would do both. First fill thru the bolt hole in the thermostat inlet housing and then adjust the reservoir as needed after the engine has been 'burped' (temperature cycled and all air purged). Quote Link to comment Share on other sites More sharing options...
88anthonyd Posted December 27, 2013 Author Share Posted December 27, 2013 How do you burp or purge the system. I filled up the inlet then I filled reservoir then I screwed everything on. Am I suppose to leave inlet unscrewd then turn on engine? Quote Link to comment Share on other sites More sharing options...
landar Posted December 27, 2013 Share Posted December 27, 2013 How do you burp or purge the system. I filled up the inlet then I filled reservoir then I screwed everything on. Am I suppose to leave inlet unscrewd then turn on engine? Once you initially fill the block, you put the inlet screw back in and tighten. Any additional filling will now be accomplished via the reservoir. To purge, you start your engine and get it up to operating temperature. Put the heating system on full heat (hot) with the blow fan running. Keep the RPMs up around 2,000 - 2500 for a couple of minutes. Keep an eye on the reservoir level and keep it between the Hi and Low levels. You should soon feel heat coming from the vents. You will have to watch the level in the reservoir over the next few days of driving to ensure that the engine is filled and that there are not leaks. Thats it. Pretty easy. Quote Link to comment Share on other sites More sharing options...
