KentRoorda Posted October 1, 2013 Posted October 1, 2013 On 2011, 12, 13 + vehicles, the 'Maintenance Required' display will display User Defined maintenance items which can be set in your Nav/Display on your dash. It will also display 'Maintenance Required' every 5000 miles to remind you to check the oil (even though the oil now only has to be changed every 10k miles). When the display is reminding you of one of the User Defined Maintenance items, you can simply reset it by resetting that item on your dash display. However, if it's reminding you of an oil change, the procedure is a little more secret; hence unknown!..... At least until this moment, which I will share the procedure with you! :) If your "Maintenance Required' display has come on at a 5k mile interval and you have checked or changed your oil, then you can reset and clear that display by: 1. While the ignition is on, press your Odo/Trip button until the Odometer is on Trip A. 2. Turn the vehicle off. 3. Press and hold in the Odo/Trip button and, with your foot OFF the brake, press the Start button TWICE and keep holding in the Odo/Trip button until you see the 'Maintenance Needed' display clear and reset. 4. Turn off the ignition. Cheers
pj8708 Posted October 2, 2013 Posted October 2, 2013 On 2011, 12, 13 + vehicles, the 'Maintenance Required' display will display User Defined maintenance items which can be set in your Nav/Display on your dash. It will also display 'Maintenance Required' every 5000 miles to remind you to check the oil (even though the oil now only has to be changed every 10k miles). When the display is reminding you of one of the User Defined Maintenance items, you can simply reset it by resetting that item on your dash display. However, if it's reminding you of an oil change, the procedure is a little more secret; hence unknown!..... At least until this moment, which I will share the procedure with you! :) If your "Maintenance Required' display has come on at a 5k mile interval and you have checked or changed your oil, then you can reset and clear that display by: 1. While the ignition is on, press your Odo/Trip button until the Odometer is on Trip A. 2. Turn the vehicle off. 3. Press and hold in the Odo/Trip button and, with your foot OFF the brake, press the Start button TWICE and keep holding in the Odo/Trip button until you see the 'Maintenance Needed' display clear and reset. 4. Turn off the ignition. Cheers Thanks!!
SteveinATX Posted October 2, 2014 Posted October 2, 2014 For my 2007 GX470, this was the procedure that worked: http://us.lexusownersclub.com/forums/topic/30149-resetting-maintence-required-light/ Many Thanks! Steve
