Replacing Starter
BillyC
OK, the concensus seems to be that my starter staying engaged too long on my 91 LS 400 is caused by a sticking solenoid (plunger). Consequently, I have a few questions:
1. Is a replacement solenoid available, or must the whole starter assembly be replaced?
2. How is the starter accessed?
3. Is this a job that a "do it yourselfer" can handle?
Thanks,
BillyC 91LS400
BillyC,
This is a big job - $800+ probably @ lexus dealer..... its buried under the intake manifold in rear of engine.
Procedure of major component removal:
disconnect acclerator cable
remove air cleaner/intake connector
Disconnect throttle body
Remove intake manifold assembly
Remove water bypass joint
obviously, you'll have to drain coolant/replace gaskets, etc....several items...
If you have another set of wheels and devote the weekend....you can get it done
99
