003sGsuxeL Posted September 9, 2013 Share Posted September 9, 2013 Has anyone run into this problem before? After an oil change I reset the oil maint reqd light it said it was successful and right away oil maint reqd comes back on I did it four times already and it keeps coming back. Does anyone know what to do? Thanks for your help! Quote Link to comment Share on other sites More sharing options...
GDixon Posted September 9, 2013 Share Posted September 9, 2013 I suppose you could unhook the battery for 30 minutes or so. That will reset the computer. That is an extreme, but usually successful, solution to computer glitches. After hooking it back up be sure to check the manual to see what accessories have to be reset - like sunroof, windows, radio, etc. Quote Link to comment Share on other sites More sharing options...
003sGsuxeL Posted September 10, 2013 Author Share Posted September 10, 2013 I will give that a try today thanks! Quote Link to comment Share on other sites More sharing options...
JimRob Posted December 7, 2013 Share Posted December 7, 2013 Did you find the hidden button somewhere under the dash that resets the light? I had to take my 2011 GS350 to the dealer and even their technician had trouble finding the button. Quote Link to comment Share on other sites More sharing options...
Pied1946 Posted November 26, 2014 Share Posted November 26, 2014 Aidas: Go to the info button on your Navigation Unit, then to Maintenance, Select Oil - Reset, Filter - Reset this one also. Both of these need to be reset as they are connected to Oil Maintenance related. Then everything is reset and you should be good to go. Quote Link to comment Share on other sites More sharing options...
