Fogcity Posted May 24, 2013 Share Posted May 24, 2013 Can anyone help me with the best replacement "Manual Shock" for the front, ...the back air shocks seem to be holding up with no leakage,.... Is it possible to Just replace the front Only.? Thank You Very Much. Quote Link to comment Share on other sites More sharing options...
steve2006 Posted May 24, 2013 Share Posted May 24, 2013 You could I guess just replace the fronts but then you will have to block off the front air lines and trick the AS system into thinking there are still air struts all around. Why don't you just convert the lot to springs and do away with the air? http://www.lextreme.com/ascon.html 1 Quote Link to comment Share on other sites More sharing options...
Fogcity Posted May 24, 2013 Author Share Posted May 24, 2013 Thanks Steve, now what kind of shocks will work best without lowering the chassis too much. Thanks for your help Sir. Quote Link to comment Share on other sites More sharing options...
steve2006 Posted May 27, 2013 Share Posted May 27, 2013 If you go for a set of coilovers you can adjust the set up to your liking, plenty to chose from on ebay.com. 1 Quote Link to comment Share on other sites More sharing options...
Garo_mcc Posted May 28, 2013 Share Posted May 28, 2013 I just ordered some sensen quick struts for the rear. Got them from rockauto, only $118 each, will let you know how they fit, ride etc when I put them in. Quote Link to comment Share on other sites More sharing options...
