A Thump Or Clunking Noise
Recently when I back out of the garage ( over a 1 inch drop ) I hear a loud thump or clunking noise comming from the rear of the car.
Any ideas ?
dave
  • 6 months later...
Check out the spare tire compartment. There may be some tools not fastened down as they should be. Also, most people have found that there is always that little "thump" when you leave for work,just to remind you that it's going to be a bumpy day!
Just a poor effort at humor.
Paul
Not funny, it will only get worse over time backing out of or turning into drivway over a 2 in. lip. Complained several times to dealer and was told problem is with the sunroof. This way they avoid tearing into the rear suspension as nothing obvious under car. Still working on this will advise if cause found. Any one else with the problem?
......how long has thump existed...did get progressive worse....does it only happen in reverse gear....can another person hear it from outside car...does it only go thunk once when you go in reverse...
strange sounds are hard to isolate....JimB
