Idler Pulley And Tensioner Pulley
Anjumkha
1996 LS 400
I wanted to change the serpentine belt, but I found the idler pulley making a noise. In addition The tensioner pulley is also making a slight noise.
Questions:
1, How do you remove the tensioner pulley ( not the whole thing, only the pulley) , Turn clock wise or counter clockwise?
2. What is the number of the tensioner pulley bearing?
I plan to replace the bearings on both , tensioner and the idler puleyy.
Thanks
M Khan
richardkwon:
I removed the tensioner pulley yesterday. Before removing I found the correct answer on Lexusclub; the tensioner pulley should be turned CLOCKWISE for removal.
The idler pulley bolt can be removed as any normal bolt, by turning counterclockwise
  • Like 1
