LMS Teacher Posted February 18, 2013 Share Posted February 18, 2013 Wife's 06 LS430 clicked as she tried to start it. She tried again and it started right up. Suspected the battery, but it was replaced in 2010. Her proximity key battery is the original one, so she took mine and had not more problems. Am I just lucky or is there still a gremlin hiding under there to bite her when she comes out to start it at night? Will the key, which she keeps in her purse, make the engine appear like she has a dead battery? And then work fine. Quote Link to comment Share on other sites More sharing options...
landar Posted February 19, 2013 Share Posted February 19, 2013 If the 'no start' was a series of rapid clicks then your car battery is either on the way out or there is a poor connection in the post to cable clamps. It is not unusual to have a battery only last 2-3 yrs. Have the battery checked out and clean the connectors to be sure. If the key battery were low, you probably would not be able to unlock the doors or even get a click. Quote Link to comment Share on other sites More sharing options...
LMS Teacher Posted February 19, 2013 Author Share Posted February 19, 2013 She took her "key" to the dealer and had a new battery installed. Last two days no more issues, but she had my proximity key and now her key with new battery. Not one problem. Battery cables are absolutely clean, water in battery is good, and when it turns over, it is fast. So my thinking it was the switch not sending the right signal or enough of a signal to the car to tell it to start, yet enough to unlock the ingnition switch. I will keep you posted. Quote Link to comment Share on other sites More sharing options...
LMS Teacher Posted February 25, 2013 Author Share Posted February 25, 2013 Well it's been about a week since the battery in the proximity key was replaced, and that appears to have been the problem. So chalk it up to blind luck, but I wonder how many car batteries have been replaced by dealers for big bucks, and them knowing to also replace the battery in the proximity key but not include the $5 key battery on the service sheet. I would have been none the wiser. Quote Link to comment Share on other sites More sharing options...
natey2 Posted February 25, 2013 Share Posted February 25, 2013 You can buy 5 branded CR2025 batteries for under $2 on Amazon. Avoid the unheard of brands. Could have been worse. You could have taken it to Sears and have them tell you that you really need a new Alternator. Lol! Quote Link to comment Share on other sites More sharing options...
