LisaPizza Posted November 25, 2012 Share Posted November 25, 2012 Greetings!! I was replacing my radiator I purchased(aftermarket) on Ebay. Everything fit exactly EXCEPT the coolant temperature sensor connector at the bottom of the radiator....I used the one I had originally in the car and the thread won't even reach to screw it in because the sensor is too long. I tried to find a brass adapter for it because I believe there aren't any CTS out there that are shorter for my LS400. Im stumped. It is a little thinner than the original radiator. but my only issue is making this sensor fit!! Anyone with a similar problem??Any ideas on where to get an adapter? Ive been to Lowe's. I couldn't find anything;( Quote Link to comment Share on other sites More sharing options...
James Horning Posted November 26, 2012 Share Posted November 26, 2012 Compare the inlet and outlets of the radiator hoses and the mounting of the fan shroud first before changing anything. You may need to just get the correct radiator. Quote Link to comment Share on other sites More sharing options...
LisaPizza Posted November 27, 2012 Author Share Posted November 27, 2012 Thanks for the reply!! I called even if it was too late to return, they still are going to send me a return sticker and refund my $$:) Im going to go somewhere else. Thanks again Quote Link to comment Share on other sites More sharing options...
