mgilly Posted September 26, 2012 Share Posted September 26, 2012 Just checking , but at nite are the transmisions numbers supose to light up when car lights are on. Quote Link to comment Share on other sites More sharing options...
fsuguy Posted September 28, 2012 Share Posted September 28, 2012 Hi, If you are referring to the "D","N","R","1","2" - these are the gear indicators, and yes, usually they light up if the key is in the ignition and turned on. If your indicator lights are not, then it is possible the bulbs are burned out, although not likely they would all fail at the same time!! It is more likely that you have some kind of break in the wiring, or some other type of problem with your wirint or switching in the neutral start switch. Hope this helps. Quote Link to comment Share on other sites More sharing options...
mgilly Posted September 28, 2012 Author Share Posted September 28, 2012 i will remove console and check it tomorrow .thanks Quote Link to comment Share on other sites More sharing options...
mgilly Posted September 30, 2012 Author Share Posted September 30, 2012 checked connections / fuses nothing , has me bafled.was ok a few weeks ago Quote Link to comment Share on other sites More sharing options...
mgilly Posted October 2, 2012 Author Share Posted October 2, 2012 one of the heated seat lights and the other two headlight wash and vrs lighting out Quote Link to comment Share on other sites More sharing options...
Micah.Berry Posted October 9, 2012 Share Posted October 9, 2012 When you pulled the center console out, did you happen to replace the VRS and the heated seats connectors (and get them firmly seated into the sockets?)? One of my heated seat button bulbs just burned out, which I have ordered from Sewell. $6.50 or so + $9 shipping. Ouch. Ordered another one just in case any of the other bulbs decide to call it quits, and to spread the $9 shipping costs just a little. Seems a little odd that your lights would be going out at an accelerated rate. If the connectors weren't seated firmly, then they could have been dislodged with when you re-installed the center console. Micah Quote Link to comment Share on other sites More sharing options...
mgilly Posted October 11, 2012 Author Share Posted October 11, 2012 will check that again thanks Quote Link to comment Share on other sites More sharing options...
mgilly Posted October 25, 2012 Author Share Posted October 25, 2012 Now lads the centre console illumination still aint back some do light some dont, i wonder is it a earth Quote Link to comment Share on other sites More sharing options...
