97 Ls400 Bad Sensor?
nates97 ls400
I got a 97 ls400 and when I got it the check engine light was on. So I had the code pulled and it said the right bank cam sensor was bad. So I bought a new one, replaced the bad one and reset the computer. So after all that I start it up and runs fine. No light, all good. later that day, I got in it to take off and the check engine lights back on and it wants to die and then dose. When I try to start it Agin, it dose the same thing and doesn't want to rev. so I unplugged the cam sensor and it turns over and runs pretty good. Other then a little hesitation and longer then normal cranking when started. What dose anyone think the problem is?
