where do i add freon? i looked a lot, can't figure it out! it's ok if you call me stupid! Found a port
on the driver side of radiator header, but the cap has a H on it. is this the high port?
  • 3 weeks later...
Dont think you can add freon. The 98 SC is using a CFC refrigirants (r134) i believe. I have no idea how to replace it. You could take it to a shop?
You are right,the cap marked "H" is the high pressure port. Low pressure port,cap marked "L",is on the passenger side of the engine compartment, close to the firewall. Not easy to spot,but it's there.
