paulenka1 Posted June 6, 2012 Posted June 6, 2012 check engine light on, search in google,check engine light on means one or more diagnostic trouble codes (DTC) are stored in the engine control module. should i go to garage repair it or get a code scanner to clear the DTCs, if i want to get a code scanner, which tool can do 2010 lexus rx, have a chance look for the maxiscan jp701 and Professional Japanese Car u695, which tool is better? give me some suggesthions!
gamagin Posted July 8, 2012 Posted July 8, 2012 Hello. One of the best bits of advice I read here and use, not specific to your question, was to take your Lexus to a reliable toyota mechanic or dealership to get a less expensive analysis of what your problem may be. At that point, you can also find out what kind of equipment one of these folks use & buy it or just take it to this place in the future. Good luck. I notice you are in Idaho. I'm next door in WA. best regards, Jerry
Georgia42 Posted July 13, 2012 Posted July 13, 2012 have you bought it ? in my opininos MaxiScan JP701 is better for you !!! i want to know more details about a new release car key prog T300 plus ,you know about the tool????????chinasinoy
drakelouis29 Posted July 24, 2012 Posted July 24, 2012 maxiscan jp701 is anytime best than the other. most of the people use the same even i also prefer it.
