  • 1 month later...
Well I have a 95 sc 300. I started by removing the belt. Then I removed the pully. Then I drained the reservoir. After that I removed the bolts that held it in. I bought just the power steering pump so I had too transfer the reservoir. Then everything in revers. Fairly simple.
  • 3 months later...
click on www.lexls.com, then go under maintenance. A diy with easy pictures to follow and rebuild.
