dockhawk Posted May 29, 2012 Share Posted May 29, 2012 Ball Joints Is It A Big Job can any good mechanic change them is there an thing special? Quote Link to comment Share on other sites More sharing options...
landar Posted May 30, 2012 Share Posted May 30, 2012 Not too bad -> http://www.lexls.com/tutorials/suspension/flowerarm.html Quote Link to comment Share on other sites More sharing options...
yotoy82 Posted June 7, 2012 Share Posted June 7, 2012 Its not a big job at all. Get original LEXUS parts from sewell with the discount, and don't forget to get an alignment afterwards. Quote Link to comment Share on other sites More sharing options...
BentBrain Posted June 10, 2012 Share Posted June 10, 2012 You can save like 300$ if you buy the doorman which is identical to the Toyota arm and has the same ball joint. I've only done the uppers but even with air shocks it only took about an hour each side. Mostly 14-19mm bolts and nuts if I remember correctly. Very easy DIY job IMO. Quote Link to comment Share on other sites More sharing options...
