topgun129 Posted May 16, 2012 Share Posted May 16, 2012 Hi, I have a 99 Lexus ES300 and just noticed today that when I apply the brake I hear a creaking noise coming from the front of the car. It only happens when I apply the brake. I also tried it when I started the car and it wasn't happening (no noise) and then after driving for 15 mins. it started occuring. Any idea what that could be and is it serious? Thanks! Quote Link to comment Share on other sites More sharing options...
topgun129 Posted May 16, 2012 Author Share Posted May 16, 2012 Hi All, I checked the brakes and the pads are good with a lot of life left on them. I also checked the brake fluid and that is at max. The noise is only coming from the front driver side. Quote Link to comment Share on other sites More sharing options...
gbhrps Posted May 17, 2012 Share Posted May 17, 2012 topgun129, This is pretty common. Its nothing to worry about, if you've checked to ensure that the brakes don't need servicing. Several of my cars have done the same thing over the years (my 07 Subaru Outback does it at present). You may be able to correct the creaking noise if you dismantle the brakes, and clean and lube the slide pins, pads, and caliper shims, etc. This may correct the noise for a short time. To completely erradicate it will most likely require new pads, calipers and rotors. I'd just live with the noise, as long as you're sure the brakes are fine. Quote Link to comment Share on other sites More sharing options...
