Headlight Standard To Oem Xenon
You will need the OEM HID housing, bulb, and ballast. Forget about the leveling computer because that involves so much other electronics (wiring, sensors) that even Lexus techs don't want to tackle that job (read lots of $$$).
Once you have the 3 parts listed above, it is pretty much a replacement.
Thanks Neo I'll be on the look out! Biggest concern was the stock wiring sockets.
Appreciate it.
Except for the bulb/socket, the OEM system is somewhat like aftermarket kits. The 9006 connector will go into the ballast. The nice thing is that the housing has room made for the ballast below the housing so that everything fits in nice and neat.
