Was wondering if bleeding the brakes is any different than a Non-ABS system. Have bled brakes without ABS and is more time consuming than difficult. Is there anything special that I need to be aware of when bleeding brakes with an ABS system?
Also, any tips and advice would be greatly appreciated.
In general, whenever you are bleeding an ABS-equipped vehicle you can do so exactly as you would any other vehicle - stroke the pedal to pressurize the system, open a bleeder, close the same bleeder, and repeat. This does not change whether you are pressure-bleeding, vacuum-bleeding, or manual-bleeding. Manually bleed RR, LR, RF, LF brakes.
