654Life! Posted April 6, 2012 Share Posted April 6, 2012 Can someone please help me correct/ fix this problem? Also! when i drive uphills my car start to smoke! Smells like overheating, but it's not! HELP PLEASE?? Quote Link to comment Share on other sites More sharing options...
landar Posted April 7, 2012 Share Posted April 7, 2012 Can someone please help me correct/ fix this problem? Also! when i drive uphills my car start to smoke! Smells like overheating, but it's not! HELP PLEASE?? So, you filled the washer fluid container yet the warning light stayed on? Check to see if the sensor wires are still attached. It could also be a faulty sensor. On the smoking problem...not a clue unless your parking brake is stuck on. Quote Link to comment Share on other sites More sharing options...
steve2006 Posted April 9, 2012 Share Posted April 9, 2012 Common problem on the late LS400, the float in the waher bottle sensor gets stuck as it absorbs water and gives a false reading. There was a fix tutorial around I will post the link if I can find it Found it!!! http://www.lexusownersclub.co.uk/forum/index.php?showtopic=31393&st=0&p=360415&hl=+washer%20+level%20+sensor&fromsearch=1entry360415 Quote Link to comment Share on other sites More sharing options...
