Lexus Es 300
EZO
Hello
i have a Lexus ES300 with check engine light and that have code p0325 and p0330 knock sensors. i changed my knock sensors and circuit, but i steel have check engine light and that code . can you help me please?
Hello
Have you cleared the codes, might be old? I assume whoever did the sensors much have disconnected the battery.
Did you check the wiring from the connector below cyl 5 back to the ECM? If this is bad, replacing the sensors won't make a difference.
And of course, the ECM may be bad as well.
LL
Hello
I went to this LINK and replaced everything including Knock sensor wiring harness because the wiring and plug were toast. It gets really hot in this area between cylinders.
