Gear Box No Ay To Drive In 2Wd
kilog
Hi
I have a 2000 Lexus RX300 1MZ-FE MCU15 engine
The snow button works but is OFF
The car is running 4WD, NO WAY to turn it 2WD, the outside temp here is 32°C
When I check the DTC, there is no fault. No DTC to acknoledge or to erase, everything is CORRECT
When I drive the car at the gear spead D, the car changes gear at 5.5rpm
that is too muh, as normally it should be around 2.000 or 2.500rpm
What is wrong with my car
HAT SHOULD I DO TO Bring it back at 2WD
Regards
