toytrain Posted October 19, 2011 Share Posted October 19, 2011 Passenger window on my 2003 SC430 goes up and down as it should when opening/closing the top but won't raise or lower using control on either door. Driver window OK. I've checked fuses 35, 41 and 42 - all OK. Motor seems to work OK as window does raise/lower. Did I miss any other fuses? Any ideas? Quote Link to comment Share on other sites More sharing options...
driver7 Posted May 11, 2016 Share Posted May 11, 2016 On 10/19/2011 at 6:26 PM, toytrain said: Passenger window on my 2003 SC430 goes up and down as it should when opening/closing the top but won't raise or lower using control on either door. Driver window OK. I've checked fuses 35, 41 and 42 - all OK. Motor seems to work OK as window does raise/lower. Did I miss any other fuses? Any ideas? Quote Link to comment Share on other sites More sharing options...
driver7 Posted May 11, 2016 Share Posted May 11, 2016 Did you solve this? I'm having the same problem on my 2005 SC430. It happened right after I opened and closed the hard top one morning to clean the rear window. Thanks Quote Link to comment Share on other sites More sharing options...
Drivin Dave Posted September 27, 2016 Share Posted September 27, 2016 Same problem on 2002 sc430...help? Quote Link to comment Share on other sites More sharing options...
