lexus mom Posted October 14, 2011 Posted October 14, 2011 Recently had car DIE (nothing worked)bec auto service tech jumpstarted in reverse! Now with new battery and fuses replaced including main fuse to alternator. Car runs OK. But two interior lights went out (dome and driver visor light) simultaneously and headlights don't turn off automatically. Told latter is related to problem w driver's side door actuator...but power locks work ok from door switch. What's wrong...actuator, switch, or electrical system betw actuator/switch and body control module? Any commonality w wiring/ fuses, BCM parts that control interior lights? Also the D setting on shift display won't light up tho all other settings, i.e. P/R etc do. Related??? Thanks.
code58 Posted October 15, 2011 Posted October 15, 2011 I would say you need to get the auto service (or their insurance company involved). If those things all worked before the reverse jump, it's their problem, not yours. That is a HUGH NO, NO! Can do a LOT of damage in spite of the fact that fuses blew, as it seems to have. Yes, I believe it's related!
