Zierhga Posted August 5, 2011 Share Posted August 5, 2011 I have a 2005 RX330. Recently I was out and when I stopped and tried to get out, the driver's door would not open (from inside or outside). With the door closed, it appears to be impossible to get the door panel off to get at the door mechanism without ruining it. With the door closed, the dashboard and door frame prevent the panel from being removed. Neither my local Lexus dealer, nor my mechanic can figure a way to get the panel off intact. Has anyone else experienced this problem and come up with a less expensive fix? Thanks for you help. Quote Link to comment Share on other sites More sharing options...
