Brake Issues In Ls
Eric_Tovar
My 1991 LS 400 with about 265,000 miles has recently been acting funny. I have lost brake pressure while having 75% or better of the brake pads in the front. I feel like the pedal is almost going to the floor and I am getting very little stopping power compared to how sensitive and powerful the brakes used to be. What could be the cause? Any and all help is very much appreciated.
Note: I have also added brake fluid once during this time period because it was low.
If you have had to top up the brake fluid more than normally (due to pad wear takeup) check for any leaks or bulging brake hoses when under pressure first, does the brake pedal travel get less if you pump the pedal?
