Help Me Please!
I just got a diognastic test done on my 1999 es300 and here is what the mechanic told me was wrong
Air/fuel ration sensor- Replace B1
thermostat
Mass air Flow sensor
Replace faulty B2 VVT solenoid
Spark Plugs
The guy also advised the 100,000 routine maintance done for the timing belt
what should i replace first and how much time you think i have to drive it like this. Also do you know of any websites that i can get some of these parts for cheep I really dont need top of the line parts because im not going to be raceing the car you kno i just want it back to good standing. Well have a good weekend lexus world and hopefully some one can help me
Berry B
Bare,
Sounds like bad news, but most of these things are not critical as to keeping the car running. I'm always suspicious of mechs quoting large capital gains projects. Here are some of my thoughts:
This is not an uncommon sensor to fail, and the result usually is that fuel economy suffers. The fact that its reading this code, doesn't nessicarily mean the sensor is bad, as this could be due to the system running too lean as if there was a vacuum, intake or exhaust leak, not to mention a malfunting MAF sensor. You can get an AF sensor for $50-$150, or more if you go to the dealer. Not impossible to swap out yourself but you need long arms, an adventurous spirit and a 7/8 in box wrench (if memory serves me well). AF sensors are like spark plugs in that they go bad as they age, so replacing w/ new vrs used is the way to go if you can afford it.
>thermostat
The tstat is prolly stuck open, which means the coolant takes longer to heat up. May be a problem in winter. IF the car is overheating, due to tstat not opening, then replace it immediately.
This sensor is a box attached to the air intake hose running from the air filter housing to the throttle body. Easy to replace (10 minutes), but first I'd take it off and spray the internals (inside the air intake hose) with electrical contact cleaner. That often helps. Again, not a critical part. $30 bucks used (yard or ebay), but in the mid 100's for new.
This is part of the emmisions system (as are the AF and MAF sensors), not sure what it does, but I doubt its critical. I got the whole emmissions rail which has 4 sensors (one of which is the vvt)at the local pullapart for $25. Not too difficult to replace, need to get the cover off the top and there they are sitting above bank 2 (front bank).
>Spark Plugs
Ya, you prolly need them. Front bank (B2) are fairly easy, but the rear bank is a bear, as you have to take the whole intake side off down to the intake manifold. About 8 hours the first time you do it. Be sure to buy irridium plugs ($7-8 each), as they'll last another 100k. Car will continue to run until these old boys burn out, but will begin to run quite roughly as they're on the way.
>>Timing belt
I believe the '99 is still a non interference engine, and as such, if the tb breaks, the car will stop, but no damage will occur. The valves are perpendicular to the cylinders so if the belt breaks the pistons will just bump them up and down. Interference engines have valves that come down at an angle to the pistons and get bent easily when the belt breaks. You might be able to get many more miles on your belt before it snaps. Might try to inspect it by taking the top tb cover off. Google your engine model with the word "non interference" and you will can find a list showing it.
Overall, the news isn't as bad as you think. If you like to wrench, you could take care of all of this for $300-$500 in parts and hours of fun and excitement. But don't be surprised if in a few weeks another sensor will send a CEL. Might want to invest in a scan guage (I have one that interfaces my computer with the car's, spent $30 for the cable on ebay), so you can see the codes for yourself, and not get the crap scared out of you by the Lexus dealership. Also investing in a Haynes manual for your year is also a good use of $. Can find reasonable prices for parts at rockauto.com and there are dozen of other sites out there as well.
LL
