Stephen8229 Posted March 31, 2011 Share Posted March 31, 2011 Hi everyone. These two lights have been on for over 6 months now. Car runs fine (126,000 miles), but I was wondering if this was an easy (inexpensive) fix? Midas Muffler did a quick code check and came up with this @ code check: Knock Sensor 2, Circuit Malfunction, (bank 2) Lexus told me that if the engine light isn't blinking, that it's probably nothing serious, and the light is steady. So is the 'Trac Off' light. Can anyone shed some light on these codes? Thanks for your time! Quote Link to comment Share on other sites More sharing options...
Lexlogic Posted April 2, 2011 Share Posted April 2, 2011 Hi everyone. These two lights have been on for over 6 months now. Car runs fine (126,000 miles), but I was wondering if this was an easy (inexpensive) fix? Midas Muffler did a quick code check and came up with this @ code check: Knock Sensor 2, Circuit Malfunction, (bank 2) Lexus told me that if the engine light isn't blinking, that it's probably nothing serious, and the light is steady. So is the 'Trac Off' light. Can anyone shed some light on these codes? Thanks for your time! I replaced my Knock Sensor it took 6-9 Hours. Here is the link Quote Link to comment Share on other sites More sharing options...
lexis lexus Posted April 3, 2011 Share Posted April 3, 2011 Knock sensor isn't a disabling condition, but when it's out, the computer does things to prevent knocking, like enriching the fuel mix, advancing the timing, and sometimes turn off overdrive; overall reduces effiency. Usually the problem is the wiring harness, but in my case, both knock sensors were toasted as well when I got to them. LL Quote Link to comment Share on other sites More sharing options...
