Resetting The Tire Pressure
If it is the same as the 2006 GS, then it should be directly under the steering column about 2 to 3 inches in under the dash.
If that doesn't work, check the other button (Main Set/2nd Set button). It is under the dash below left bottom corner of the glove compartment. This button gets hit accidentally if your passenger has a handbag or package by their feet. I find this button gets switched more often than I like. Poor location if you ask me.
steviej
It was right there! I guess I should have looked a little lower! Light went out.
Thanks Steve.
On another subject...has anyone tried Griots car products? I have a friend that restores old cars and he swears by their products. Just cruious if its worth the extra $$$.
