Cruise Control Inoperable
Woozy
I searched and there was only one thread on this topic, and not much info there. Here is the situation. When the cruise main id pressed the light in the dash goes on, not sure if this means the fuse is good or not. When I try to set the speed the cruise light on the gash goes out, and obviously it is not set. it also flashes the cruse light in the dash 1 or 2 times, then it remains off. Can anyone tell me where the CC ECU is located? Would that be a good place to start, assuming that the fuse is good? If not whjere should I start? Thanks in Advance
